Omron PLC Noob Question
kwallace
Jul 2014
Kuala Lumpur
Hi all, I took a PLC class some time ago and have since forgotten almost everything in it.
I think I can work out the programming again but I'm failing at the physical wiring connections. Which I think means I'm failing at the "understanding" of it all. In that I mean, I have a switch with 2 connections and a light with 2 connections, how does the Input/Com/Output wiring go?
I've been reading round and I actually cannot find a guide for something like this (maybe I'm not looking in the right places)
However, to get to the next step could someone please let me know how I setup a simple switch to a light. using Input 1 and output 100 (I'm using via the Omron training kit)
What I need to know is the actual wiring so it makes the connection.
Can anyone help please :whistle:
I have never used Omron, but here is a quick diagram that should put you on the right path.
I usually fuse my ouputs as will as the power supply, but you will have to choose what is right for your application.
BCS
Use Moggie's examples, except use only the "01" Input terminal to a module in Slot 0 for Input I0.01, and wire to the "00" Output terminal (instead of the "07" as shown) to a module in Slot 1 for Output O1.00.
You will not need any connections to Input I0.06 or Output O1.03.
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
87
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
177
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
146
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
210
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
135
