Omron PLC RXD TXD and Memory usage
elessarsst
Jan 2011
Expansion Socket
Hi all,
I've programmed some omron plc's with cx-one. But I've never used rs-232 communication or memory usage. Just inputs and outputs with some timers and counters.
Here is the situation:
When the RXD reads from buffer sends it to some D value i.e D100.
My question is, is there a limit to write to D100 like "100000 times writable"?
The reason that i ask is i need to set some D values to make RXD work. I'm planning to set D0001 word 0x0101 to setup RXD configurations "EACH TIME I ENABLE AN SPECIFIC INPUT". If there is a limit i can't do what i planned to do.
That is a good question, but I do not think there is a limit.
D memory is battery backed RAM, not flash or eeprom.
Also, make sure you look at the RS232 pinout on the PLC.
Omron does not use a standard pin configuration.
Hope this will help.
It helped me lot ty very much..
I don't plan to connect plc atm but i'll be careful ty.
I've found out i can monitor that data area with "PLC MEMORY" add-on.
Also I can edit and D value for example i can change D0000 value 0xFFFF.
Is it dangerous? I'm not editing DM or other areas. Just unreserved ones.
If not then this values that i transfer with "PLC MEMORY" add-on, are being kept in eeprom and when the power is on, eeprom sends this value to D area?
I don't think that i understand the battery backed thing. Since i'm not using battery.
I'm asking it because When i monitor this area there are some values on every d value."Is it because i've programmed some input output functions"
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
57
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
165
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
134
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
196
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
124
