Omron Prog Console
indra
Apr 2005
indonesia
161
I have 2 (two) type of OMRON PROGRAMMING CONSOLE, type PRO27 and PRO01. Does any one knows : WHAT ARE THE DIFFERENCES BETWEEN THEM ?
And please also inform me : WHERE I CAN DOWNLOAD THE MANUAL INSTRUCTION OF PROGRAMMING CONSOLE "PRO01"
Regards,
INDRA
Paulus said:
Hello Indra,
The basic difference is that the PRO27 can record / retrieve a program to / from a cassette tape.
Here is a link to the manual...
http://oeiwcsnts1.omron.com/pdfcatal.nsf/PDFLookupByUniqueID/F04707A48D99369A86256B580078A463/$FILE/M11W341E1040204.pdf?OpenElement
Paulus, Indra,
I was having trouble with the link posted, "Cannot find server". It may be working now.
If it is not, here is another link to the same manual:
http://forums.mrplc.com/index.php?download=253
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
72
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
112
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
157
