OMRON Speed Control PLC
bigbri
Jan 2011
UK
After a SYSWIN ladder diagram that could be used to control speed of a servo motor, with a Fine, Medium and course push button.
I thought of something like this, as a start (obviously no where near finished!!)
Each Incremental counter will be set at a different value for speed control of motor. I.e Fine, medium, course!!!
Am I starting off on the right foot here ??????
Thanks all
Not really enough information provided to answer your question.
What plc are you using?
How is the servo motor speed controlled?
Pulse output? Value in a memory location?
The Omron INC instruction increases the value of the referenced memory location by 1 for each scan it is enabled. I am not sure that what you really need to do.
Hope this will help.
currently operating machine that is currently using a CJ1m-CPU22 this sends an analog output to FR-FC inputs on the drive then links the next...
6,446
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
883
Hi Folks. I have a problem with an Omron CPM2A-60CDT1-D High Speed Counter. It had been working well, the problem arose when a very minor program...
1,471
Hi Folks. I have a problem with an Omron CPM2A High Speed Counter. It had been working well, but the problem is that a program change was...
1,381
Hello Gentelmans, In the begin, I'd like to thank you for help with my previous problem about external display to Omron JX inverter, finaly we...
4,150
