Omron's Devicenet configurator and CX_integrator
Boyko
Oct 2005
26
Hi.
Recently I started reading the Omron's Devicenet manuals and found the "Devicenet configurator" software higly recommended. I don't have it in my CX-One packet, but there is a CX-integrator. So, does the CX-integrator cover the Devicenet configurator functions?
If No, do I really need buying Devicenet integrator? Is it usefull?
_________
Regards
Boyko
yes, CX integrator can cover the device net configurator..
you must read the manual and check about your processor and device you used ?
G'day All, Having some trouble with an omron devicenet network with nodes going into bus fault. CPU is a CS1G with a DRM21-V1 devicenet maser...
1,873
Hello Everyone, I am trying to setup/debug a devicenet network, but can find where the variables have been setup. The Sysmac manual mentions...
1,074
History: On an Omron CJ1W-DRM21 Network, had a servo driven actuator that went bust. This node is in the middle of the memory map (node 6), with...
1,739
Hello forum members, We are having a frustrating issue (yet again with my favorite network - Devicenet). We have an ABB robot that works with an...
4,014
Hi I am working repairing some old machines, 3 omron an 1 AB using devicenet, there is a CP1H with a CJ1W-DRM21 as master in node 63, two CPM1A...
1,517
