one RSview32 paramater file is not big enough
terry56
May 2010
California
45
One of my team members is working on a rather large RSView32 project. He has about 50 tags on a template page that will be updated via a parameter file. The trouble is there are >1,500 tags for the parameter file (thats more than the 500 limit)
So, my question to you gurus is: Can the parameter file name be specified in a string tag, or somehow else dynamically changed?
Thanks for any help :unsure:
Greetings terry and welcome to the forum.
1500 tags is way more than you can practically display on a single screen. The 500 parameter limit is even greater than you can realistically present on a single screen.
If a template page has 50 parameter tags then only 50 tags are needed in the parameter file.
Parameter files allow you to re-use the same graphic for displaying similar data.
For example, you might want to display data on twenty different tanks in a tank farm. You create one graphic display page which can then be loaded twenty different times with twenty different parameter files - but only one graphic has to be created instead of twenty different graphics.
Thanks Alaric, but I should expand a little more:
*The template screen shows 50 Power Meter parameters
*There are 30 power meters on the network, so thats my 1500 tags
Can the parameter file name be "passed" in using a macro?
I say stuff doing it all in the HMI and do it the "old fashion way" in the PLC.
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
397
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,926
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
609
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,452
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,315
