One shot instruction in SLC/05
fluoronator
Feb 2006
North Alabama
What is the difference between the ONS and OSR instructions in the SLC/05. I've read the help for both instructions but the difference was not apparent to me.
The OSR (one Shot Rising) is for the 5/05
The ONS instruction is not available for the 5/05 its for the micrologix 1200 and 1500 and looks to me to be the same.
edit: On the 1200 and 1500 the OSR is an Output where as on the SLC its an Input. But the ONS is not available on any SLC.
ONS is not available in the SLC 5/05, only the OSR is. In the MicroLogix, both are used, but differently.
Try using them in the various processor types. You will see how the ONS is "grayed out" when you choose a 5/04 processor. You will also see the difference in how they are applied.
It was obvious to me when I played around.
ONS is used when passing "power flow"
OSR is used like an output instruction where you specify storage and output bits.
EDIT: 504bloke's post above is very definitive. I still suggest playing around in the RS Logix software.
The SLC500 is the odd ball when it comes to one shots. The PLC5 family had the ONS inline instruction and the OSR and OSF output instructions, which have been continued in the MicroLogix and ControlLogix family.
Certain models in the SLC500 family also are a bit funny about how they handle one shots on branched rungs as well. The fixed SLC, 5/01 and 5/02 don't properly process one shots in branches. Refer to the manual for more info.
Hello everyone, I am a beginner in PLC programming and I need your help. I am trying to use a one-shot instruction in my program just to see how...
1,800
I am new with siemens which instruction is used as Rising Edge One Shot. |p|. I need whenever Rising edge is detect only execute instruction one...
3,574
The code of Emergency switch is following, when you press the switch the machine stop. In ControlFunctions : DIFU and DIFD is same variable ...
6,423
Just curious what is considered a one shot with direct logic software. Help would be great thanks DM
6,252
Hi all, I'm trying to dectect the true to false transistion of a bit. I'm using a PLC5-40/E processor. I've decided to use the OSF instruction...
8,985
