Online edit errors in RSLogx500
CQ21
Apr 2021
Columbia
61
Hello all,
I am having an issue with online edits in RSLogix500 (v11). It is throwing me these weird errors when I try to either save rung edits or assemble edits (pics attached). It is very strange and inconsistent and sometimes it lets me make changes online without a problem. I am positive it is not my edit because when I download offline it does so successfully. If anyone has experience with this issue any input would be greatly appreciated.
Thanks in advance!
I am assuming you are using Ethernet for your connection. In RSLinx go to Communications and Configure CIP Options.
Change these settings
Max "Fast" Messaging Connections per PLC change to 1
Max "Slow" Messaging Connections per PLC change to 1
This resolved a similar issue I had.
OG
EDIT: I didn't opt for the graphic so I beat sharkyh2o to the punch :)
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,055
Good Morning , I went to edit a rung , and for some reason I can “ Accept Pending Rung Edits “ , but I can’t assemble rung . I...
17
6,330
Good Morning , I need to make a online change to a SLC 500 5/05 . Is it safe to turn the key from Run to Remote with causing the processor...
1,873
Good Afternoon, I'm trying to do online edits on a SLC 500 5/05 . After I put my instruction in , I keep getting " Test Edits Failed " ...
3,753
I can't do Edit Online, even edit toolbar just show Start Pending Rung Edit and the rest are gray (Not showed). I checked the other users, all...
5,616
