op/pc communication
mrsenolsezer
Dec 2004
49
Siemens OP7 to PC communication is my problem. I need 9 pin D-Sub Female to 15 Pin D-Sub Male cable Pin Assignments.
Thanks for your cooperation.
I could't find it in siemens site.
Hi, Heres the exact Pin Out of the Cable, I believe it will work without all the links in the 9 Pin side.
9 Pin Female
2 green-------------------------- pin 3 15 pin Male
3 Yellow------------------------- pin 4
5 grey-------------------------- pin 12
7----
7&8 linked together (9 pin only)
8----
9 not used
1----
4----
1,4&6 linked together
6---- 9 pin only
Cable screen to casing on both plugs
All the best
Steve
Stevo are u sure, i've found a siemens document (Equipment Manual OP7) it says:
For D-15 female
and for RS 232 (its important as u know i'll use serial communication)
Pin 3 : RxD
Pin 4 : TxD
Pin 5 : CTS
Pin 10: RTS
and the other pins are empty. But i don't know the exact truth.
So what is your configuration depending on (i don't want to be suspicious but...?)
Thanks RolfB at least i've found it with your help, that is it, what i exacttly looking for. Thanks for the link..
Have a nice year everyone...
We had a site where a rat gnawed through some fiber optic cables which (obviously) prevented communication to a remote rack entirely. We, and the...
38
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
98
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
18
392
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
233
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
44
