OP170 Program Upload
Prince
Jun 2002
284
Is it possible to Upload the project and edit from an OP170 ?
We are using Wincc and MPI connection...
Prince,
Are you wanting to edit the configuration while it is in the OP170? Or are you wanting to get the configuration out of the OP170 and then edit on your computer?
I wanted to edit in my computer but if it is possible to edit it directly on the OP I won't mind.
I just don't have the source ...
Prince,
If you do not have the source code you are out of luck. You can down load the compiled configuration using Prosave and use it again, but you can not change it. In some of the OP's the programmer may have saved the configuration file (uncompiled) in the OP if it has enough memory. I do not think you can edit any configuration directly on the OP.
Larry
Hello! I created a project in step 7 V5.2! And I created project in WinCC flex. 2005 V1.01 (communication op170, MPI, CPU 300)! My question is...
2,789
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
292
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
118
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
136
my ccw softwer stops working when i add and try to open a ladder program.
85
