OP27, Battery
orense
Apr 2006
Norway
196
Hello,
Does anybody know what happens if I get the system message on an OP27 that backup battery is almost dead?
- If the 24 V disappears after the battery is dead, what happens?
- Will the total configuration be lost, or only the message and event buffers?
Thanks everybody :)
Andreas
Hi Andreas
The manual says the following:
The backup battery ensures that, in the event of a power failure
 the operating data in the SRAM of the OP are retained and
 the hardware clock does not stop.
A lithium battery is used in the OP. It is already fitted when the device is supplied. It has a typical service life under normal operating conditions of approximately four years. An exhausted battery is indicated in routine operation by a
system message on the OP. Replace the backup battery as quickly as possible after the message is issued.
It does not say whether your configuration is in SRAM or not, buts the phrase "Replace the backup battery as quickly as possible after the message is issued" makes me think it very well could be.
You can download the manual via http://support.automation.siemens.com search for op27.
I am working on a project to back up software for a number of machines for a client, and am having problems connecting to SIMOVERT MasterDrives...
3,182
Hello ALL, I don't have much experience-thanks for help. I am trying to configure trending on OP27 using ProTool. I just need to display...
1,437
Hi, I'm wondering if it is possible to convert an uploaded OP27 file to use in a newer Siemens HMI? My understanding is that you can only upload...
1,911
hello everyone, i m trying to rebuild an old machine sitting idle for many years. it has a OP27 panel and 2 CPUs (314 and 316). i did connect the...
2,278
Hi, I'm working on a machine with these two HMI screens, but we do not have any back up. I believe it is possible to take a snap-shot of the...
6,735
