I'm trying to get a connection between a OP3 and an S7-215-2DP CPU; I programmed the OP3 with protool, so far no problem. I gave the OP3 adress 3 and the Connection peer adress 2. I selected DP and 9.6 bits/s.
I connected The OP3 on the DP PORT, and it seems that it's also 9.6 kbits/s.
On the OP I see: AS Adress 2 not found.
How is that possible, what should I do ?
I use variables V0 to V12; programmed in the OP, but not yet in the CPU, I don't think that i my problem,
help
help
