OPC Communication
ikon2018
May 2005
I was testing out OPC communication between Siemens WinCC and ABB SCADA System I had few difficulties in accessing the OPCServer of WinCC. The version of WinCC I am using is WinCC Version 5.1 and when ever I am trying to connect to the OPCServer.WinCC from the Matrikon OPC Tuneller it is giving this message: OPCcommn_PS.DLL: Old Version Installed. And when I am clicking this message as OK, another message is popping up and it says communication to OPCServer.WinCC not established. And when I went into the details of the error the following message is displayed:
COM/OPC error 0x80040154 on CoCreateInstance()
Error String: Class not Registered
Additional: Could not connect to “OPCServer.WinCC”
I have also installed the patch for registry and done the necessary changes in the system registry for OPCServer of WinCC. Few days back I have tested the same communication with WinCC version 6.0 and was successful. I would like to have a solution for this problem as the WinCC being used here is of Version 5.1.
And I have one more question. Last time when I used WinCC Version 6.0 and connected to the ABB server I downloaded all the tags and placed then under OPC.chn driver. When I was trying to check the OPC data transfer and communication the changes was not reflected in my system when the tags were in OPC chn group. When I placed the same tags in internal tags group the communication was established and data transfer was taking place.
Hence if you could please provide me a solution for both these problems at the earliest then it would be great.
Regards
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
225
Trying to use the APPICOM OPC server that comes with Bradcommunications APPLICOM Card for wornderware. When I "browse" the OPC tags I get Group...
4,330
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,709
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,826
Hi, Has anyone communicated Rexroth IndtaControl PLC CML40.2 with over OPC or MODBUS TCP/IP? I am working on a Project for MES where i need to...
1,595
