open close servomotor body
Kataeb
Jan 2007
www.livelovelebanon.com
636
Can we open a servomotor body, then reassemble it again without issues ?
Because the customs at the airport want to see the inside of the motor !
We have limited tools on site .
Any special tricks ?
1FK7105-2AF71-1RG1
I've also seen issues when removing the integrated encoder from the shaft. If that's a part of the disassembly you're attempting, you'll have to re-phase the encoder. Which will require intervention from the manufacturer and/or their service facilities. In my experience, they don't release information for that procedure.
Just don't do it. Customs in your country have x-rays and CTs that can detect almost everything. They can check it and see it without opening the motor. If they do not want to do it, you need to file official complain.
If you remove encoder there is practically no way to return it in correct position without special tool and software. I think that encoder has 20bit resolution.
Hi Can anyone send me 5 or 6 graphics for a valve showing the following states for TIA Portal v15.1 wincc open opening close closing faulted...
2,383
Hi all, I have multiple goto buttons that open up display windows when clicked on. However, I want to make it so that when I click on one of the...
5,687
Hi, I have several goto page buttons that bring up small popups on the screen. I would like to be able to have an open popup automatically close...
15,320
Hi I want to create, open, write and close a .txt file. And it works fine. BUT I can't do it again. I have to reactive the hole system before I...
4,106
Hi, we are using DeltaV Dcs. We have problem with Motorized damper, we have motorized damper, But position feedback ( 0 - 100%)is there. How to...
1,909
