Organising folders in RsView32 Tag DB
sparky64
May 2003
Newcastle upon Tyne
127
I'm trying to organise the Tags in an already written RSView project.
The guy who developed the project, has created all of the tags in the root folder.
i want to move the tags into folders that are broken down by machine number, alarm folder etc.
Does anyone know if it is possible to move tags from the root folder into another folder.
Cheers
Sparky
The only way to "move" tags between folders would be to use the "duplicate folder" function. Then remove the tags in the old folder and/or remove tags in the new folder that you dont want to move also.
As all tags are in the root folder you will have to do a lot of deleting to remove unwanted tags in the new folders.
I also think that you may have to update all (!) uses of the tags in the various animations, buttons, datalogs etc.
PhilipW said:
Create the folders you want then, export the db into a csv file and do all your editing in excel.
You beat me to it, Philip!
Sparky, it's probably a good thing that you want to put your tags into sub folders. Rockwell has advised me against putting too many tags in the root folder. Since I started doing this in RSViewSE, I've noticed a considerable performance improvement.
AK
Thanks for the replies.
I was hoping there was a quick non energetic way of moving all the tags to the new folders.
I guess i'll have to do it the slow way in excel with the CSV files.
Cheers
Sparky
What do you mean, slow?
It's hard to make it easier than "Fill-Down" and Copy-Paste.
If you're REALLY bored, you could waste a whole bunch of time and write a Visual Basic application to do all the work for you. (y)
AK
I am trying to set up network folders to be used with FactoryTalk software. For many years I have been able to store my 500 and 5000 programs on...
1,709
What exactly does this command do and when do I want to do so? Is there an instance when I should not do it? Help is good....but it has nothing I...
1,757
I don't know what I did but here goes... I made a tag and added it to the folder. I then went to the momentary button I made and clicked on its...
1,370
Hello recently install eds corresponding to a VFD ACS800, the installation went smoothly, in the final message seems to keep hardware in the...
1,675
Hi all, I reformatted my laptop over the weekend because it was suffering from bloat. I moved the contents of my (old) C drive over to a...
1,832
