Organize S7-1200 Data Log .csv data
h20pt
May 2010
Portugal
31
Hi
I've sucefully implemented the data logging function with the s7-1200 1212C, but when i open the data log file in .csv excel format it shows something like this:
Me question is: is there a way to auto-arrange the data when saved on the .csv file so it won't stay all in the same column (comma separated values) but each type on each column?
Thank you
I think excel should be able to open this correctly, maybe you should fiddle with import options?
otherwise post the .csv file here so we can take a look
It may be also be a good time to look at excel macros as well. Good example is after you have imported the csv file, is setting the cell data format, resizing coloumns, creating a graph, printing, saving to your network folder as pdf etc etc all with one click.
I am beginner in B&R Automation Studio and TIA Portal. Have an experience in electrical part of PLC cabinets. Now its time to get a new skills...
1,703
I just about have my siemens project wrapped up, and all my DB, FC, and FB numbers are all over the place. Is there a simple way to organize...
2,099
Hello I need to organize data exchange between Siemens S7-400 and Schneider M340 PLC via ethernet. I created a connection between S7-400 CPU and...
2,341
I am trying to get RSView to display and print selected alarms. What I would like to be able to do is select a start date and end date for a...
2,577
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
75
