OS copy of Beckhoff CX1020
buscaruidos
May 2011
Castellon
I have a Beckhoff CX1020 Embedded PC here without OS. (CF dead!!)
I tryed to setup Win XP embedded without success. Avery time I get a Blue Screen!
Can anybody supply me with an XP embedded Image, which will run on this target?
I have also downloaded a Image from the Beckhoff FTP-Server.
ftp://ftp.beckhoff.com/Software/embPC-Control/CX10xx/CX1020/XPE/
The problem is that all the ZIP files are password protected!
I will appreciated your help!
Thankssssss!
I understand that the Win XPE image from Beckhoff includes Twincat run-time w/ license. Judging from their price sheet, the run-time appears to cost ~$500. They only provide it on their own PC's. If you are the original owner, Beckhoff should be able to fix you. If not, there may still be a valid license associated with the PC, so beg your local salesman.
To use the CX as a general PC, you might install regular Win XP, if it can fit on the memory card. To make a custom XP image, I requires expensive Microsoft software. But that approach would not allow it to work with Beckhoff modules, unless you install the full TwinCAT-PLC programming environment (~$1200).
Windows XP embedded is licensed similar to Windows XP OEM.
So Beckhoff should be able to supply you with an image file at no cost.
Why not contact their support ?
Thank you.
I did, but because it had not purchased directly from Beckhoff Spain ... Beckhoff response "f_ck you" ...
To update the firmware of my modules BK or Bc € 70 unit ... sent to his office ...
very good service!
regards
117
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
98
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
183
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
1,025
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
672
