OT:5Vdc prox sensor
Soggy Canuck
Jan 2008
Vancouver
229
I have a three wire unsheilded M12 prox sensor at one of our customers. It has been sorely abused over the years and I attempted to replace it. The partial part # leads me to believe it was an obsolete Balluff PNP. I crossed it to an Omron and installed the replacement (surprise, surprise!) it did not work. Checking the power supply I found it was running on 5 Volts DC. Balluff insists that none of their sensors would ever have run on that voltage. The Part# BES 516 356 E4 Y5 is my best guess as to what remains of the cable (run into various gears a few times (I'm not kidding). Has anyone ever found a three wire M12 prox that will work at 5Vdc?
I have never heard of a M12 prox that is operated on 5 volts.
The 5 volt power supply, does the label say that is the output voltage, or is that a meter measured voltage.?
Reason for the question is, could there be a short and the power supply is lowering the voltage, so that the current is not exceeded, switch mode power supplies can do that but usually go to a lower voltage than 5 volts.
Disconnect the wiring from the power supply and measure the no load voltage.
This prox is hooked up to an OEM counter the customer had purchased with a handmade photosensor of some kind. The photosensor died and someone (previous technician) had stumbled onto this sensor as a subsitute. Opening up the counter I found a 5 volt regulator, and I have never seen a Prox running on 5Vdc either.
Mike
Hello, I am tasked with designing a 115VDC power supply to power a 115VDC magnet. I believe this magnet would usually be powered by a generator...
2,637
Hello, I've never worked with voltage output transducers before. I've only used current transducers (4-20mA). I am working with an old...
4,037
Good evening guys, I'm in need of a power supply (or 2) for a home project. I want to go from my 120v supply to 24vdc (1.5a) AND 5V DC (500MA)...
3,923
I have a temperature sensor that runs from 0-5vDC. I would like my computer to be able to turn on 3 different cooling fans at the different volts...
2,228
Hello everyone, I'm looking for a redundance module 125VDC that can be mount on DIN rail for power supply. 2xInputs, 1xOutput. I only found a...
1,712
