OT : Are routers good as Network Switches
So, consumer grade routers, such as the ones supplied by many ISPs, do not handle large amounts of packets well.
They can 'lock up' as the internal hardware gets overwhelmed dealing with this sort of thing. Plus many of them have subpar cooling for any kind of 'actual' workload.
Unmanaged switches, like the trusty 5 port netgears many of us use and love have nothing that helps to mitigate this.
So yes, a better router(I personally love my TPLink ones as I can schedule them to restart periodically) might very well help. Or some better cooling ala heatsinks, or a box fan. Or just power cycle the thing every couple days *shrug*
I had been having a ton of issues. I switched my ISP router into bridged mode, I switched my wireless router into AP mode, and then bought an Edgerouter X. Once I turned on QoS, it solved the last of my problems, or at least the ones that were in-house infrastructure issues.
https://www.ui.com/edgemax/edgerouter-x/
I still have an old iPad that will drop wifi in the middle of my son watching videos, even while it has good signal, and refuses to reconnect until i reboot, but I'm assuming that it is a client issue.
I actually built a script to monitor pings to a number of devices on the home network, as well as doing speed testing, and then a web interface I can monitor that from, view historical trends, etc. Since I got that running, I haven't had an issue yet.
If you need stability and good control over your netwowrk you could use the ISP router as modem and then have a MikroTik router or EdgeRouter doing all the routing and switching work.
unmanaged switches poll every comm port for information.
managed switches as I under stand things, asks if you need data or have data making them more efficient. if I am wrong, someone please correct me.
james
You are mostly correct.
Unmanaged switches poll all ports.
Managed switches can be configured to direct certain communications between individual ports, including turning off ports. You can also monitor speed of communications and some other values.
Cascaded switches can cause problems. The three parallel switches should be no issue but any switches under a switch has this issue as I understand it:
Every port on a switch records the MAC address of the device on that port. So when you ask for a device that has been previously recorded, there are no "WHERE IS" message broadcasts; the switch goes right to that device. If that device on the port is another switch, every time a message comes upstream from a device on that cascaded switch, it has to record another MAC address and another and another all by broadcasting to all the network WHERE IS such-and-such over and over.
My office/shop setup:
ISP Modem/Router. ISP programmed it to bypass the router function.
First step in: NetGate SG-5100 Firewall - pfSense software factory version
6 usable ports but I only use one to go to:
Planet GSW 2404SF 24 Port managed switch.
Wireless access: ASUS AQC1200 dual band - no hardware plugged it.
Get yourself Wireshark and watch what's happening. Look for unnecessary broadcasting and even unknown devices.
Huawei's problem is overblown. I be more worried about all the Alexa and webcam devices. There are no zero risk with anything but we should know enough to put things in perspective.
What I found is that "managed switch" means very different things to different vendors. When most IT says "managed switch" it means a Cisco switch with IOS that can do port-protection, STP, ether-channel, etc.. etc..
In the industrial realm, take the popular NTron switch for example, it doesn't do half of the stuff that a standard Cisco can do, nor do most industrial user ever need all the functionality either. Cisco is also very very slow in booting up so I hate putting it in industrial environment (Rockwell's Stratix is basically re-branded Cisco)..
TikTok was created in China. The militaries of other countries (can't remember which) banned any service personnel from installing it, because it was harvesting data. Source: Seplicity
So it's ok for US companies to harvest data from users (Facebook, Microsoft, CIA) but it's not ok for Chinese?
Your argument is so ridiculous, sounded just like a commie trying to tell us covid-19 was released by US.
When a user sign up for free FB, MSN service, somewhere in the fine print, he/she already accepted that some personal data will be collected.
I don't understand why you even mentioned CIA, it's a government agency and yet there is law that govern in case they decided to track someone.
On the other hand, when a consumer purchase a router from HUAWEI, he/she did not expect that router is spying on ALL activities and sent it the Chinese government. And we all know from the past and present experience, many intellectual properties are stolen by the Chinese.
Enough said!
Curious as to whether anyone has experience utilizing Ubiquiti EdgeMax routers and switches in a light industrial environment...
1,117
Hello all, This topic was discussed as a secondary one in the link below, but I wanted to create a separate and updated thread...
2,319
does anyone have any experience with class 1 div 2 industrial routers. Ive been looking at the various major brands and it seems that the sixnet...
1,391
Hi! Could anybody shed some light on this topic and tell his experience and recommendations. We are interested in placing an industrial router...
2,798
Over the last several years we've setup 25 or so VPNs at customer locations. Initially we used a Netopia ENT-3386 router as a PPTP endpoint and...
4,253
