OT: Old program requirements PL7-07
mrtweaver
May 2007
Bloomsburg
329
We use to have a UMAX Laptop. However the unit died. IT dept purchased a used but good IBM latptop. Same parameters as the old laptop with serial ports and such. The they went and installed Windows XP. The old UMAX used Win98.
Anyway we went to install the software we use. Most of it went OK the one sticky point is with a software package called PL7-07. It is for the old outdated TSX - Nano PLC's (modicon, group schneider, etc..) Anyway it would not access the serial port. It was version 3.0 The tech got me in touch with the correct area to get ahold of version 4.4 which he claimed would work with the TSX Nano and also with Win XP.
However it will not hook up to the TSX nano it say something about unknown PLC. When I try to follow the config files I see TSX Micro and Micro Pro but nothing about NANO. Has anyone worked with these? Have you used WinXP? If so what version of PL7-07 did you use? How did you configure it? Thanks and have a great day.
I had the same problem a year back, and i solved it like this:
1. make a virtual "pc" (I used microsoft virtual pc) on your WIN-XP PC
2. Install your WIN98 on the virtual PC (I think I used Win311, can't rember)
3. Install your old PL7-07 software.
You may have to make some adjustment for the virtual pc, but it worked fine for me.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
116
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
647
Got a problem on an install this weekend I'm hoping someone can help out on. I'm upgrading an old system with a SLC5/04 and Panelview 600...
1,156
Just had the anomaly. Stamping press, 20 years old, SLC5/04 CPU with EEPROM memory module. The customer says suddenly a couple days ago they...
25
9,639
We have a very old piece of equipment ('97) that a customer would like us to upgrade the controls to Rockwell. The original program was written...
2,406
