OT: panel builders, how do you cut din rail?
lesmar96
May 2017
PA
520
We are checking into several options for an upgrading our method of cutting din rail while assembling control panels. We would like an efficient tool that does not make a lot of dust and dirt.
Saw some online that looked pretty decent, but looking for others input as well.
Do you use a tool like this?
https://www.dinrailwiringduct.com/din-rail-cutters/
Thank you.
Mitre saw Ā£50 comes with (think it's called) TCT blade... cuts steel, plastic, wood all on one blade. Quick de-burr with a file.
Saw some online
Pun unintended, I assume :)
Most of our panel building is outsourced. On the rare occassions where I do need to cut DIN rail I am a sinner and just pick up an angle grinder in the metal workshop. It is both quick and dirty and not how it is supposed to be done.
Cut off blade on a grinder and then change to a flap disk to clean it up.... I would love to have a Phoenix Contact one but just would not use it enough, Siemens rail is made from aluminum and I do have a couple compound miter saws that that works perfect on them
Anyone have any recommendation for small wire ties guns... other than dykes and needle nose I use a lot of small wire ties (4 inch) and had a...
3,660
When you build a panel, do you megger the wires after you run them but prior to connecting them? What standard do you use to determine whether...
2,109
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
147
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
116
We have boiler control system runs on A-B PLC. The interface is A-B Panel View Plus 7, mounted on the local control panel very near the boiler...
149
