OT - Question
Steve Etter
Apr 2002
Morristown, TN
965
Got a quick question - When mounting an SCR, there is a white "grease" they put in between it and its mount. Can someone tell me what this "grease" is called?
Thanks.
Steve
I call it 'Heatsink compound' - but i'm sure variations will follow...!! (y)
I also use a silicon based oil sometimes.
Rob.
APPLY IT SPARINGLY!
You want a very thin film on the device, and on the heatsink. If it 'oozes' out when you clamp them together, it's generally too much.
When the two metal pieces (SCR and heatsink) are touching they are only doing so at small points. Viewed on the microscopic level the face of the SCR and the heatsink appear to have massive hills and valleys. Only the 'peaks' of the hills of each device are touching and transferring heat. The purpose of the 'heat sink compound' is to fill in the 'valleys' and provide a better heat transfer path than the air. It only take an incredible thin film. Any more actually forces the 'peaks' apart and makes the heat transfer worse.
A little dab 'l do ya. You only want enough to fill the tool marks in the heat sink.
Also I recommend using disposable gloves. Even then it will probably end up on your nose, ears, elbows, and other unexpected places. (I have a much less polite way of explaining this to new techs, but posting it would probably get me spanked here). The stuff starts white but leaves dark gray marks everywhere, and I do mean everywhere.
Just to round the topic out, if you are using thermal compound on something like a microprocessor, the white compound is not what you want to use. Spend the extra money for a good silver based compound .
Also, before re-assembling anything that uses a heat transfer compound, REMOVE THE OLD COMPOUND COMPLETELY. Use a fast evaporating solvent if needed, but get rid of the old gunk.
An electrical joint compound like EJC #2 is actually better. Heat sink compound is great for heat transfering but is a lousy conductor of electricity.
Thoroughly clean the surfaces of the heat sink(s) and the mating surfaces of the SCR. After doing this, DO NOT TOUCH the surfaces. I have seen too many finger prints on hockey pucks and heat sinks after they failed.
I hope you have tested the snubber circuits.
Back when I used to do a lot of overclocking with my pc and really researched thermal compound a lot, the best I came across was Arctic Silver
http://www.frozencpu.com/thr-16.html
It always worked great, and made a noticeable difference in the operating temps. of my cpu.
Again, only put about a "rice grain size" amount on the bottom of the heatsink when attaching to the processor.
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
180
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
103
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
100
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
106
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
97
