OT: Touch Screen Pointer
sie625
Aug 2005
Chicago
24
I suppose this is only slightly OT since it does relate to a vision system in our plant, but I am looking for some type of pointer that will work for a capacitive touch screen. Until recently I believed that these were somehow "heat activated" which i have found out is not true.
I read the basics of how they work, but without jumping into it too far i am curious why only a finger works on these screens. Some of the operators have a hard time using some of the smaller buttons, and since this is a custom application from an outside vendor a pointer of some kind would be more attracive than rearranging the screen layout.
Thanks for any input.
Capacitive Touch Screens have a charge on the surface. Your body acts as a ground, and draws off some of the surface charge. The Stylus should be metal. If the operator has gloved hands, then try using a Stylus with a ground wire attached.
You might just as well replace the touchscreen with a larger model now. After a couple of months of encouraging the operators to use a smaller (read that as sharper) pointing device, the screen is going to get so scratched that they won't be able to read it any longer.
IMHO, it is irresponsible design for the OEM to create touch zones that are too small for reliable actuation by an operator's finger.
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
108
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
153
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
111
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
660
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,476
