OTE tag tagname.[something] DINT
Dera bsee
Sep 2012
Los Angeles
36
Hello all,
I've never came across an OTE with a tag name like this
tagname.[something]
The tag is a DINT. What are the scare brackets for and what's
the purpose of programming a tag that way? o_O
Look up Indirect addressing in the help file. The something is a tag that allows you to change what address is used. It's value will determine what bit the OTE represents.
If something = 0 then Tagname.[something] = Tagname.0
If something = 5 then Tagname.[something] = Tagname.5
Greetings. I have a project in PanelView Plus 1000, that cosist in datalogging some variables using the ActiveX object DataStorePlus. For that...
1,460
So I did another project in ControlLogix (v15.65 Redundancy) not too long ago where I had a controller tag aliased to a digital input module...
7,135
wonderware Analog Tag values to remote pc Sql Server to Remote PC hey everyone, i currently...
3,341
Sql Server to Remote PC hey everyone, i currently am running SQL server for my wonderware intouch 9.5.1 i need to get 3...
1,987
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
31
