Panbuilder 1400e upload application won't open
russrmartin
Aug 2002
Eastman, Wisconsin
744
Hey guys. We have a Panelbuilder 1400e that when we upload the application, it uploads fine, and is saved as a .PVD file. When we try to open this in Panelbuilder, it says that it cannot find the blah blah blah, .IDX file. What is this? I have found several on my computer, but all of them are about 2K and I don't know what any of them do. Has anyone else had trouble uploading an application and getting it to work in Panelbuilder again? We're knda stuck if we ever want to make changes to this thing. Thanks in advance.
Russ
update
Well, I finally decided to just go ahead and reload PB1400e software. Now instead of the previous problem, I get the following erro, BTM caused a generic protection fault in module GFIL10.dll. Anyone seen this? I'm lost.
Russ
Someone else asked the same question in THIS message in 'another' forum. It never got answered, but the first post in that thread mentions something about incompatibility with a Windows update. Might be worth a shot... :confused:
beerchug
-Eric
Thanks a lot
Thanks a lot Eric. This explains a lot. I will add a post to that thread, and hopefully by now someone has the cure. If not, it seems to me like I need some of our IT help for this one. Thanks also for the info on this forum. I'll be keeping an eye on that one as well.
Russ
This is a known issue that is induced by Microsoft update/hotfix KB828741.
Rockwell has this document:
P81834218 - PanelBuilder 1400E - fails when trying to open an application in WIN2000 or WIN XP Pro
To resolve this you must call Microsoft:
Computers with WINDOWS 2000 SP4:
Customers must contact Microsoft for patch KB840999
The patch KB840999 is available only through Microsoft.
For computers with Windows XP SP1:
Customers must contact Microsoft for patch KB841559
The patch KB841559 is available only through Microsoft.
There are several contact phone numbers, based on a customers support contract with MS.
The following link can help identify contact methods: http://support.microsoft.com/default.aspx?pr=cntactms&style=home
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,702
I am attempting to mix old with new. I have a 1400e HMI that is communicating to a plc5 via DH+. I need to set the HMI up to read some of its...
2,404
Hello everybody, I am working on a project where the customer has several panelviews (PV1000e, PV1400 standard, PV1400e) which have model numbers...
1,710
If it had a modem it would be damned near ideal. I still have at least half-a-dozen sites I call into using a modem. Besides the Rockwell stuff...
1,277
