Panel Interface Connectors
maintpro
May 2003
Osceola, IN
28
I want to install a Mencom Corp. panel interface connector onto one of my control cabinets to allow me to connect to my Micrologix 1500 PLC without opening the panel.
I was wondering if anyone can tell me what type of connector is used on the end of the micrologix programming cable that plugs into the PLC? :confused:
Panel Interface Connection
Maybe my question is too simple for the likes of you all or maybe you just don't understand the question. :unsure:
I am not a complete dumb a** moon2 and do know that one end of the cable has a 9-pin D-sub connector.
The end that plugs into the PLC looks like a 8-pin mini din connector. In fact, the pins are in the identical locations as a mini din. The only problem is that a regular mini din connector will not plug into it.
So now my question is; does anybody know what type of connector is on the end of the cable that plugs into the Micrologix?
Been there, done that...
Yup, too simple for the likes of us... ;)
See THIS THREAD and THIS THREAD
If you're using a ML1500, go for the 1764-LRP processor which adds a second 'normal' (DB9) COM port... :nodi:
beerchug
-Eric
I was simply using micrologix programming cable as
connection from PLC to Weidmuller programming port
and simple straight through cable outside the cabinet.
Each time I would keep the original 9-pin connector
from the programming port. It comes in handy for
custom cables or testing thanks to neatly labeled
screw terminals.
hi all i want to add operator interface to mutshibishi plc Fx1s-series,, can any one guide which operator interface can directly communicate with...
2,686
I am looking for a panel interface similar to the one below that can handle a Allen Bradley dh485 connection. Any ever see one...
2,386
:shock: Greetings all: Is there anybody here that are about to be required to "suit up" when you open up a control panel to troubleshoot? I came...
5,719
I'm looking for an Operator Interface panel that is capable of generating reports into a Secure PDF format to meet FDA requirements. Space is an...
2,229
I am new to using the Proface touch panel. Currently for a project i need to link a Siemens S7-314 PLC with the Proface 5.7" Touch panel...
7,189
