Panel View 550
ggchavhan
Nov 2006
pune
135
HI
I am having PanelView 550, with DH 485 port, But I don't have AIC converter Can it be possible to download the program the program by using RS485 t0 RS 232 converter, and after downloading DH485 of PV550 to SLC500. Please help me
It would help if we knew the complete part number of your PanelView 550 also your SLC500. And if your programming terminal ( laptop, desktop ) has a real serial port.
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,437
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,930
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,773
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,049
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,777
