panel view 550
Make sure the panelview requires 24 volts, then get a source whose output is 24 volts. Conect the + and - in your source to the + and - in your panelview, conect the ground. check your wiring, if everything is ok, plug in the input for your source.
how can i get 24 volts to a panel-view 550 so i can update the firm ware?
I am going to ask that you give us the full catalog number of the Panelview.
I also believe that a PV 550 is a Standard PV that uses Panel Builder software and it is my understanding that the firmware can not be updated,
this is something I think you may need to investigate.
Certain panelview standards cannot be updated past frn 1.02. I believe all those with 2.x and greater can be updated, but first we gotta get some voltage to it...
http://www.youtube.com/watch?v=g5KdP41OC3k
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,435
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,926
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,771
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,042
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,777
