panel view help me
alex_cordova
Oct 2009
paramount
102
i have an micro logix 1500 LRP
I HAVE A SERIAL POR 9 PIN AND A PROGRAMING PORT
I HAVE MY PANEL VIEW CONNECTED TO SERIAL ON SIDE OF PLC
AND MY PC CONNECTED TO PROGRAMING PORT
I HAVE MY PANEL VIEW SERIAL CABLE 9 PIN CONNECTED ON RS232 DF1 GOING TO MY PLC
OK I GO ON LINE WITH MY PC AND SEE MY PROGRAM WHEN I HIT RUN MODE ON MY PANEL VIEW 1000 AND GET 686 PANEL VIEW OFF LINE
PLEASE HELP ME, I KNOW MY SETTINGS ARE WRONG
Any change of the PLC from run to program will generate an error in the Panelview as it looses communication. Once the PLC is in 'run' acknowledge all errors on the Panelview. If it was communicating before it should communicate again.
So are you saying that all my cables are hooked correctly??
And i could be online with my pc and have my panel view online at the same time so i could see it working in my program
Yes, with two ports the LRP provides for exactly that flexibility. We typically use one as the HMI/programming (by cable swapping) while the other speaks Modbus to our AB drives. Two ports are very freeing. But then a NET-ENI connected to the serial port opens up even more channels of communication. You get what you pay for.
Hi, good afternoon to all member of the forum, I had a panelview plus 6 model 600 that recently broke down and had firmware version 8.0 installed...
529
Hello everyone, im new in Allen Bradley World, i alredy know how to use factory talk view and with manager i have alredy upload all runtime...
1,707
I developed the attached trend graph for monitoring conductivity on one pen and the setpoint on the other. When it's running the pens are in...
1,580
I'm hoping if someone can tell me what I need to do base on this convert.log file I received when I migrated a PanelBuilder32 application to FTV...
1,165
Guys I need help with a Panel View Standard 1000 Touch screen. I want to upload / Download the screen application so I can add new alarm messages...
19
8,399
