Panel View Plus display only
dcam
Apr 2012
Merced Ca
161
Hello to my ET brothers. Question, how do i make a screen display only. At some stations I do not want operators to have access to change things but they need to see the process. I have been trying in factory talk studio to find this parameter for hours.
What type of data do you want to display. Sounds like you just want a bunch of indicators.
Numatic Indicators can give you a read out like line speed, gap settings. Multistate indicators can change colors for different states and you can have captions in them or data.
There are also alarm banners or popups you could use for different conditions.
These are complex process graphics controlling various parts of the plant. I want to make certain screens observe only at certain stations. For example the milk receiving station needs to see the HTST screen but not be able to manipulate valves/routing. Any panel view station would have multiple screens for multiple systems, linked to many processors.
Im not talking about button animations ,visibility options or letter code access . Im talking about entire pages.......smell me?
You want to view (as example) the HTST screen from HMI "A" on HMI "B"
identical screen only HMI "A" has control and HMI "B" is just a mirror
image with no control?
EXACTLY CAPTAIN, sorry if my descriptions were lacking. Thought it would be the processor local design association in the factory talk linx....but I was incorrect.
Just had a Idea....what if you put a giant invis button linked to unused file over everything you wanted blocked?
That sounds like it would prevent an input.
What Panelviews are you currently running.
I have found and retrieved existing programs that have monitor only screens. I open them up in Factory talk view studio and I cant fig what is making them observe only...all symbols are linked to correct files and processor?
Im sure its my fault but this is the first time here that I have gotten no real info on my issue. I work at a cheese/protein plant that is ran primarily by stand alone processors with networked panel views. There are many panel view stations all over the plant. These stations have many screens showing various processes. Some stations currently have screens that have access to changing things like routing and set points that they should not. I know in panel view there is a way to make screens display process data only...it is a setting or parameter that I cannot find. This is not in reference to one screen i want to limit access to but MANY screens.
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
295
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
167
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
344
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
902
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
899
