panel view plus flash card
phil hughes
May 2005
31
Hi, we are using a compact flash card to collect data on our pv+ 1000.We have set up the logging model path to custom and the path is \Storage Card2\data. We are not getting any data after restarting the application,also no errors. Any ideas?
Thanks in advance Phil
I have considered using the datalogging feature with the PV+. Before I use anything but the most basic stuff on a FTView programmed HMI, I always read the technotes at ab.com. Luckily, we have techconnect access so we can see all of them.
What I read, was that there are at least a few situations in which the datalog will not start, and the Panelview may not notify you.
Has the datalog worked in the past?
Are you trying to log digital tags? If so, use an analog tag pointing to a digital address.
Does the PV+ recoginize you card? To find out, try copying the .mer file to it.
What version of FactoryBalk are you running? What PLC model(s) are you connected to?
Do you have a diagnostics screen set up in the application? It should tell you when the datalog fails. If diagnostics is not configured, you will never know it failed.
Hope this helps,
Paul
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
301
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
170
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
345
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
905
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
908
