Panelbuilder32 and PLC5
Prozac
Oct 2010
Biskra
Hi everybody…
This is my first time using the enhanced PLC 5 controller with a touch screen panel view 550.
I have problems to associate addresses with tags in the tag editor.
PUT_BIT è I:001/4 (discrete Input card on the slot 01)
GET_BIT è O:002/11 (discrete Output card on the slot 02)
When I want to download the screen to the PV I get this error message:
Error (9075) – [Tag:pUT_BIT] Tag does not have a valid address in the terminals assigned Discrete Rack or Block Transfer Channels.
Error (9075) – [Tag:GET_BIT] Tag does not have a valid address in the terminals assigned Discrete Rack or Block Transfer Channels.
Thanks for interesting.
One of the reasons to post the PanelView part number (or program) is to determine which network protocol it uses.
If the PanelView is equipped with Remote I/O, you address the PanelView's own Rack Object. The error messages you posted are characteristic of the RIO version of the PanelView.
If the PanelView is equipped with DF1 or DH+ or ControlNet or EtherNet/IP you can address the I/O database of the PLC-5 controller, as you've described.
HI guys I just got a problem when I tried to update the HMI linked with a PLC5, a new button to trigger a output, I configured the tag address...
2,137
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,448
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,087
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,638
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,266
