Panelbuilder32 firmware
sifis
Banned User
Oct 2005
OKC., OK.,USA
139
Which Panelbuilder32 has what firmware?
For example,
Panelbuilder32 3.70, what firmware?
Panelbuilder32 3.81, what firmware?
Panelbuilder32 3.83, what firmware?
For example,
Wondering? Do the RA knowledge base links posted by forum members here not work for you?
Anyway, this might be against forum rules, but it is a RA Access Level: Everyone > so here it is...
PanelView Standard Firmware available on PanelBuilder32 install files
34399 | Date Created: 02/23/2006 | Last Updated: 12/28/2016
Access Level: Everyone  Email this page
 Print  Subscribe to Updates
Question
What firmware version is on what version of PanelBuilder32 install disc?
Environment
2711-K, 2711-B, 2711-T PanelView terminals
Answer
Below is a table informing which PanelBuilder32 version contains PanelView Standard firmware.
PanelBuilder32 Software
3.83.01 4.46 / 4.48
3.83.00 4.46
3.82.01 4.41 (4.43 for 600 Touch terminals)
3.82 4.41
3.81 4.41
3.80 4.20
3.71 4.20
3.60 4.10
3.50 4.00
3.40 3.40
3.20 3.30
Revision 4.46 for all panels can be found in \PVFirmware\PV_Terminal_FW\FW_Card\ and revision 4.41 for all panels are in \PVFirmware\PV_Terminal_FW\FW_Direct\
The latest version of the PanelBuilder32 software is available on the Compatibility and Download Center at
PanelBuilder32 Software Downloads
Hope it helps,
KuulKuum
This question has not been answered, or you do not understand the question.
Assuming you are correct, what is the answer?
Yes it was, if you click on the link provided by jkerekes or the knowledgebase article provide by Ken it does give you the answer to your question.
And its free.
Edit: KuulKuum types faster then I do.
And its free.
NO, Mickey... I just copy and paste faster... lol
Question
Environment
Answer
3.83.01 4.46 / 4.48
3.83.00 4.46
3.82 4.41
3.81 4.41
3.80 4.20
3.71 4.20
3.60 4.10
3.50 4.00
3.40 3.40
3.20 3.30
Hope it helps,
KuulKuum
Perfect information.
That is EXACTLY what I was looking for.
I feel a lot better about this forum now.
Thank you.
And its free.
I guess I am not very good with the RA knowledge database.
A lot of you are a lot better than me navigating the RA knowledge database.
Thank you.
So, the problem still remains.
I tried to download a new firmware from Panelbuilder 3.83/3.82/3.81/3.71/3.70 to a 2711-B6C8/B/3.15 & I am still getting the same error 25 (boot code incompatibility) using the ATA flashcard method.
Thank you.
If your terminal currently has version 3.15, I think you will only be able to install up to version 4.20 firmware onto it.
That firmware was, according to the Knowledgebase, bundled with PanelBuilder32 versions 3.71 and 3.80 only.
To my knowledge, the firmware revision is not included in the directory path or in the filename so it is critical that you know the source of your specific firmware file, i.e. which PanelBuilder32 CD or installation file it came from.
Remember also that if you're using the ATA card method, you must obtain the firmware files from the \PVFirmware\PV_Terminal_FW\FW_Card\ directory.
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,261
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,437
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,086
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,631
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,601
