PanelMate 1755T AB DH+ Driver
bluenoser337
Apr 2003
Nova Scotia
391
I am configuring a new PanelMate. I have already transferred the latest firmware. Now I need to download the AB DH+ driver, but when I select the drivers tab in the PanelMate Transfer window, the list box is greyed out so there are no drivers to select. I have a folder of drivers in my PMCONFIG folder, but nothing can be selected on the transfer screen. My configuration software is v2.10. Thanks!!
I'm using ver 2.50.6.50b2
in case you were wondering how up-to-date your software was.
By the way, my file directory is
PMCONFIG\ONLINE\DRIVERS
is this what you have?
Brian.
Got it figured out. Didn't realize you had to had to install the drivers separately from the installation CD. All good now!!
Silver...this was my directory, too...and there were DRV files in there, but couldn't access them in the transfer utility until I installed them individually from the program CD. Thanks!!
Sliver...When I hold the bottom right corner when powering up, I don't get a "get page" button, and the cancel doesn't do anything from that point. :(
Try this,
Sliver said:
AFTER panelmate boots up
[CANCEL]
[Get Page]
[More Buttons]
[Change Date/Time]
this is from memory, but I think it's close
Brian.
This works on touch panel , I don't have any touch screens, so I don't know if this makes sense with them.
Touch panels have a membrane keypad.
Got it sliver... thanks!! The set-up screen was password protected, so it wouldn't do anything when i tried selecting it...but all good now!! Thanks again!!
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
520
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,274
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,154
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,091
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
