Panelmate Compact Monitor
chorn46562
Mar 2004
Indiana
Hello all you helpful gurus. LOL. I am just loving these Panelmate Compact I Units. Sarcasm is a dangerous thing. Here at work I have hade a Panlemate Compact screen go dead it has a connector to the Panelmate compact unit that looks like this:
___________
| o o o o |
| o o o o |
essentially just a female connector from the monitor that plugs into the compact main unit.
My question is: Does anyone know if I can modify a regular monitor such as one that has a 15 pin D shaped connector off of a regular vga monitor to work with the system temporarily until the specific monitor for the unit can be bought or repaird?
My second question is: If a regular monitor cannot be temporarily used is there a way to monitor the screen with a connection to the software? So far with the software I have I can only edit information and upload or download but cannot view it running.
I don't think that the PanelMate compact was VGA. I think the first units with VGA resolution were called the PanelMate 2000.
I'm not aware of any emulation software that will let you run the application on your PC. If I remember correctly, PanelMates of that vintage used Motorola 68000 processors running OS9.
You may be right
Hello. You may be right about that. When I got to tech support they sent me a pinout drawing of an obsolete part number. I built the cable with connectors and it did not work with any monitor I tried. I think that the boss is just gonna have to break down and buy a new monitor built for it. Thankfully those we can still get.
Thanks for responding to my questions though.
Here at my company we have inherited an automation cell that has 3 panelmate compact I screens. I have been looking for software that I can use...
3,569
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
531
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,278
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,160
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,097
