panelveiw plus comms error alarm
pauly
May 2002
South Wales,U.k
244
I am using a PV+ hmi to controllogix via ethernet and if comms to the plc is lost the operator wants an alarm to be displayed. I know that when the cable is pulled from the back of the panel all the messages come up but I want an alarm that means some thing to an operator. Any ideas?
There's a Pre-Defined Item in RSLinx Enterprise called "@IsPresent" that indicates to RSView ME whether or not the PV+ is communicating with a particular controller.
I think you can use this as an alarm trigger (I actually don't allow the Diagnostic messages display to appear on error) or as an ordinary indicator.
The options for selecting a key are F1 - F20 and K1 - K20 F1 - F10 are obvious, can anyone tell me how the others map to the remaining keys on the...
1,523
I NEED HELP ON ADRESSING AN STRING INPUT ENABLE SO I CAN ENTER LETTERS AND NUMBERS BUT WHEN I ADRESS THE VALUE ON THE BUTTON AS ST12:10 IT SHOWS...
1,849
Good Morning, I've been working on an HMI using the Panel View 5000 series. I admittedly was not very good at Factory Talk View Studio, but I...
1,014
Iam removing a Panelview600 as it is no longer supported and replacing it with a Red Lion G306A panel the PLC is a SLC500, after much research I...
2,468
Iam adding recipes to a existing program, and when I go to down olad the updated program I get an error saying " Invalid Length, Bit array cannot...
1,432
