PanelView 1000 Program Recovery
phuz
Jun 2008
Mohnton, PA
1,044
I've got an old PanelView 1000 here where I've been asked to recover the program because nobody has a copy of it.
I was led to believe that just the screen was dead, but I am unable to communicate via RS-232 nor ethernet (I don't know the IP, but attempted to force one via BootP). Fault light is solid red, and there's a high-pitched noise coming from it. Any tips or tricks to recover this?
What is the exact model number?
Chances are it's toast but there may be options.
It's a 2711-T10C20. I tried something that I thought would have a 5% chance of actually having an effect: Removed the black plastic cover, disconnected the two ribbon cables and the black pinned connector, and turned power back on. This time, the FAULT light stayed off, and the COMM light was blinking. I was able to find the IP from a port-scanner, and upload the program. Downloaded it to the new terminal, and all is well. I think they got lucky on this one because I was getting close to thinking this was going to be a full re-write.
Good work. I was going to suggest disconnecting the screen from the internal logic module but you already beat me to it. Those old PV's are a hoot to work with. I keep a Compact Flash card on me just for such the occasion.
Hi All, I have an issue trying to upload a program from an existing Panelview 1000 terminal that I was hoping I might be able to get some help...
2,225
Hello, I made the very beginner mistake of toying with solenoid connections while the power was on. As a result, I made a spark and the whole...
4,004
Trying to figure out what software is needed to program an Allen Bradley HMI 2711P-RDT-10-C I have FT View Studio for ME EN (9701-VWSTMENE) Will...
3,881
hi, i am trying to connect to a panelview 1000 (Cat#2711-t10c8) via RS232 connection to PCM5/b. A/B1784-pcm5/b is the cable i am using. The...
4,753
I'm working on upgrading our vacuum loading system for our bottle resin line, and since this is (almost) the first program I've had to write from...
1,767
