Panelview 1000 Security
AGIESKE
Apr 2004
I have a customer who wants 4 levels of security access with about 80 access codes to the screens on a Allen Bradley Panelview 1000. Normally the Panelview 1000 only has 16 available access codes. I am interfacing with a SLC 5/05. My question, is anyone aware of existing code in the SLC series that can accomodate this many access codes, that is to secure the Panelview screens throught PLC code. Thanks
AGieske
I don't know of any "canned" code to do this, but with a lot of compare statements in your SLC, I'm sure it can be made to work. I wouldn't want to be the one programming or maintaining it though!
Hopefully someone else has a better way to address this.
Good luck,
Marc
Try using a File Search and Compare (FSC) for each screen you can go to. Set up a data table for each screen with the security codes and use the search block to see if that code is "good" so that the user can access that screen. This is a pretty clean way and no compare statements to mess with.
We have a PV1000 (2711-T10C15) that had the backlight die. I did a simple upload of the application and downloaded it to our spare screen...
2,503
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
144
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
220
Hi All, I was wondering if it is possible to use parameter files that can be passed to a second page eg: --HOME ---PUMP 1 FACEPLATE (With...
1,142
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
452
