Panelview 1250+ folder path
kolii0721
May 2012
Es***
I am having a problem to log data as i do not know how to set the folder path.
I tried ME Datastore Activex and the built in data logger as well.
If i use to log using the default location i could not find the log file on the location
Can anyone help me to how to set the folder path?
Welcome to the Forum
WAG Have you started the Data Log using the DataLogOn command?
You set your data log to start under the start-up of the project or for testing you can start it using the command line and issuing a DataLogOn command. Take a look at the helps file for a more detailed explanation.
Hope this helps
I did set up in the startup of the program, and is working on my Laptop, but as soon as i download it to the terminal i do not know what folder path should set up as i do not want to log it to a default folder.
i.e.: \usb storage\logs
somehow i could not set up. I wonder if my folder path is wrong.
I do not mind to use a folder in the terminal the usb not necessary
i.e.: \my documents\logs but this path not working either
can someone write me down a correct path.
Hey guys, I'm at a bit of a loss with a problem I'm having with some PVP 1250s and hoping for some advice. In firmware and application version...
302
Hello team I have any issue with the AB PanelView 6 1250 with 11 firmware install We have 8 in total and about 6 of them if you reboot them or...
1,483
is it possible to comunicate a powerflex 753 (ccw) using ethernet 20-750-ENETR card to a panelview plus 6 1250 (factorytalk view studio me)...
1,504
Hi all, I have an ihm and I need to connect this with compact logix PLC. In factory talk this communication works well (factory talk and fisical...
2,343
Hello, I recently installed an **** Flexy 201 so we could monitor our PLCs (one SLC 500 and one Control Logix) remotely under a VPN. One of the...
2,374
