panelview 1400e pvd temp file question
koti
Mar 2005
I just uploaded the terminal application from a panelview1400e. I go to open the file and I get an error saying that the "Path to the temp folder is too long (max. 25 characters)". It's trying to go to the temp folder in my user account: c:/documents and settings/user/local settings/temp. Thus I can't open the file to edit. Does anyone know how to designate the temp file so it just goes to c:/temp or is this not the root of my problem. Any help is appreciated.
Thanks,
Koti
It might be a Windows 3.1 thing.
That version of PanelBuilder is pretty old.
Can't you move the file to a different directory once you've uploaded it?
AK
Panelbuilder "Path to the temp folder is too long ..
right click my computer, select properties
go to the advanced tab
click on "environment variables"
from here, you can edit the TEMP and TMP variables.
it's probably set to %USERPROFILE%\Local Settings\Temp, you can change this to C:\Temp or C:\WINNT\Temp
I sure hope he wasn't having the problem after all the years, but I was having the same problem now, 10 years later and this post helped me.
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
308
Hello everybody, I am working on a project where the customer has several panelviews (PV1000e, PV1400 standard, PV1400e) which have model numbers...
1,719
I have been given the task of upgrading our (anicent) PanelView 1400e 's that we have on site, with PanelView+ (1200 or 1500). I have the *.PVD...
1,927
Panelview 1400E ser E 2711E-T14C6/E, during boot up it says "waiting firmware download from PCMCIA card or serial port". I connect from the laptop...
3,655
