PanelView 300 Micro to Micro810?
Leeroy
Oct 2012
Canada
66
Is it possible for a Micro810 (2080-LC10-12QWB to be specific) to communicate to a PanelView 300 Micro? If you can what interface converter would make such connection? The Micro810 has a USB adapter it uses and the 300 Micro has a mini din connector for its RS232 port.
If you need more detail please let me know.
As far as I know, the little Micro 810's aren't networkable at all. They don't have a user serial port, and the USB connection is strictly for download.
Until RA releases Micro 830's and 850's with DF1 Serial protocol (I don't know if Release 2 is out yet), you won't be able to use an old Standard PanelView terminal with the Micro 800 series. To my knowledge, the only way to hook an A-B HMI to a Micro 800 series controller is to use Modbus RTU protocol on a PanelView Plus or PanelView Component.
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,171
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,305
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,784
I am tying to download application software to a fresh out of the box PV 300 Micro. The first hitch is a prompt that I am running v4.1xx RSLinx...
1,150
I went on a service call yesterday for a Micrologix 1500. An output wasn't activating and they wanted to know what was hanging it up. It was a...
2,816
