hopefull harry
We have a system consisting of a ML1100 with an added 2 chan analog card and a panelview + 400.
The customer wants to keep records of a pressure switch readings (a 4-20 mA analog signal scaled in the ML1100 program to 0-400) which we have setup through the panelview saving the data to a storage card installed in the panelview itself.Then by converting the data log file from the storage card using the “digconverter” utility (free download from rockwell) the customer is able to read the data using a XL spreadsheet.
At this stage the data is logged as soon as the system is powered up it is logging 0-400 kPa.The customer is only interested in readings of over 250 kPa.
My question is can a trigger be set for the panelview to only log data when when the pressure switch reading is 250 kPa and above instead of logging from the initial power up ?.
