PanelView 7 with embedded tags in alarm
lottis11
Nov 2015
adelaide
Hi Guys
We have replaced a panelview 6 plus with a new PVPlus 7 standard connected via ethernet to a SLC 505.
All works except the embedded tags in alarms, which sometimes work and sometimes does not.
I inserted the tag name by using the edit string, insert variable. I have tried it as a string and also as adding a HMI tag pointing to the same address in the plc.
The tag is Redraw 2 - Scrap On Die
/*N:5 {VAR_196A\POS_ERR_REF_RW2} NOFILL DP:0*/ or as
/*N:5 {::[196A]N20:6} NOFILL DP:0*/
I have added a text box on the alarm page, and it displays the tag correctly.
Thanks for any help
Hi All, I currently have a setup using a CLX PLC and a standard Panelview communicating over devicenet. The Panelview displays the current family...
2,430
I’m running short on time to complete this project (retirement looming), so thought I’d ask here hopefully save me some research time. I’m...
135
I've adjusted the IP of the Panelview Plus as well as the DNS servers; the screen does not show up in the search when I go to the transfer utility...
196
Replaced overlay and glass in HMI but now I can not calibrate the touch screen any suggestions.
91
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
165
