Panelview 900 question????
tonywj
Oct 2007
Louisiana
I have a AB panelview 900 monochrome ( 2711-K9A1) running firmware version 3.8.... that is wired via RIO to a PLC 5/40. The screen is going out and I was in the process of upgrading to a panelview 900 color touch screen (2711-T9C9x). I got all the programming done only to realize the new panelview is DH-485 running 4.20 firmware.
My question is: Is there anyway possible to upgrade the DH-485 to RIO.
The RIO card that's in the old panelview will plug into the new panelview, but ofcourse it doesn't recognize it.
Is this a matter of firmware, drivers, and/or jumpers????
Thanks,
Unfortunately, no. There's no field-installable firmware that can convert a PanelView Standard terminal from DH485 to RIO. You're going to have to get a RIO terminal.
This is one of the reasons that RA made the communications daughtercards on the PanelView Plus modular.
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
999
Panelview 900 communicates with SLC 5/03 PLC. When I upload the program from the panel, some buttons have the address B3/306, B3/304 etc. However...
2,443
Panelview Part #: 2711-K9A8, that communicates via DH+ to a SLC504. There are two PV's on the network. One has lost its application. Downloaded...
1,972
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model. On power up, i get error 34 which relates to an extended...
2,172
I have those old early 90's panel views in my plant. I use an old XP image to get the program back into them but maintenance wanted a way to do it...
2,386
