panelview 900
tripservices
Sep 2013
Rhode Island
Hello, I am trying to program a allen bradley panelview 900. The first thing I am suppose to do is disable printer port. I have tried but the printer port stays enable. Can any body help me?
I am new to PLCS.net
Welcome to the Forum!
In order to access the HMI's Printer Setup you will first have to access the terminal's Configuration Mode.
With the HMI powered up, simultaneously press the <- (Left Arrow) and -> (Right Arrow) keys.
Once there, scroll down to Printer Setup then, when within the Printer Setup utility, press the F10 Key; the Port Mode setting will change to "Printing Disabled"; press the F16 Key to exit Printer Setup and then the F2 Key to enter Run Mode.
Please provide the complete catalog number of your PV.
If its a DH485 protocol PV then the printer port cannot be changed, its printer only.
Cat number is 2711-T9C9
Your PV supports DH485 protocol with a RS232 port.
As I said above the printer port is fixed at printer only, it cannot be changed.
To program your PV you can use the RS232 comm port with RSLinx's 1747-PIC/AIC+ driver and a straight thru cable. You will need a real serial port on your PC/Laptop to use the 1747-PIC/AIC+ driver.
If you don't have a real serial port then a 1747-UIC ( USB to DH485 converter) will work. You can get one at link below.
http://www.ind-concepts.com/Allen_Bradley_PLC_Cables.htm
Another option to program your PV is to use a memory card. See PDF
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,013
Panelview 900 communicates with SLC 5/03 PLC. When I upload the program from the panel, some buttons have the address B3/306, B3/304 etc. However...
2,465
Panelview Part #: 2711-K9A8, that communicates via DH+ to a SLC504. There are two PV's on the network. One has lost its application. Downloaded...
1,977
A question for the hive mind, i have a Panelview 900, monochrome non touchscreen model. On power up, i get error 34 which relates to an extended...
2,187
I have those old early 90's panel views in my plant. I use an old XP image to get the program back into them but maintenance wanted a way to do it...
2,391
