Panelview C400 to CCW micro850 issues
pswalley
Dec 2014
minneapolis
I am trying to get a micro850 to communicate to a panelview C400 HMI over ethernet. Only those two components. I keep getting error codes 2 and 10 about "communication tag 0". I created a very simple two bottom HMI program with both the buttons and the global variables configured as read/write.
Should I:
Enable DHCP protocol on both or one and if one which one?
Do they both need static IP addresses?
Should I have a gateway address also for one or both?
In Connected Components in the HMI section where I enter the
IP address of the PLC-1, in the communications tab does the number that automatically populates the port section belong to the ethernet port of the HMI? Or do I have to find a specific port#? the section contains a port tab and a path tab.
Any help would be extremely appreciated. Thanks
Hi everybody, I have HMI PanelView C400 (cat: 2711C-T4T) there is a program that runs directly run as startup, I don't have access to the menu...
2,064
Hello everyone... I have in use a Panelview C400. It's OK and was running fine... But my CCW asked me that need upgrade a firmware. Downloaded and...
1,409
Dear All. I have arranged an upgrade software to convert my micrologix 1000 program for ML1400. Now I am having problem communicating my ML1400...
3,153
Hello everyone 1st post here. I have a Panelview C400 connected to a micrologix 1000 using a 1761-CBL-PM02. I need to connect my computer so that...
1,649
Hello. I am new with using PLC's. I have a AB PanelView c400 that has a bad firmware flash. When it starts up, it gets stuck on "Boot" after the...
2,400
