PanelView Communication Help
Purdue_Grad
Mar 2008
Indiana
Hello,
I am new to the RSLogix5000 software and am having trouble getting communication between my panelview and my compactlogix controller. I have a 300 Micro Panelview and a Compactlogix43 controller. I have set up the network for DH485 per the requirements of the PanelView. I have 3 AIC modules on the network. One for the PLC, one for the Panelview, and one for the workstation. In RSWho I can see all three so they are all communicating with each other. From what I have been reading I think I have to use the Map PLC/SLC Messages under the logic menu to send and recieve information from the PV and PLC. Do I also have to use a copy command in the logic or possibly a MSG instruction? I have the map setup file number 3 and tagname PanelView_Int. Any help is greatly appreciated!!!
I don't think you have to do the mapping. I think you would add the PV to the I/O config tree, may have to add it as a Generic ethernet module. Then all PV I/O would show up in your controller tags list and you can copy it to an array to make more sense of it. To write to the PV, reverse copy. I've never actually done this but, my dusty memory banks recall coming across a setup similar to this.
I have a 2711-T10G20 1000 Std. with ethernet comms. I tried using a hub and fail then tried crossover cable and cannot even ping, my PLC pings...
1,600
Hello friends, I am developing a application for Panelview plus 1000 colour using SLC 5/04 PLC. I have following with me : 1) SLC 5/04 PLC...
13,775
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
711
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
903
I have a panelview plus 6 1000 that I am trying to VNC into. I have the VNC settings correct on the panelview but I get a message that the...
2,374
