PanelView Component Download Issues
jrsnydley
Dec 2014
Minnesota
155
Hello everyone, I have a 2711C-T4T with firmware 1.80. I am using Connected Components Workbench v10.00 to attempt to download an application to the terminal. When I try to download it says "Connecting to graphic terminal...Failed." Does anybody know why this is happening? I have an Ethernet cable plugged directly from my PC into the terminal. If I ping the IP address of the terminal, everything comes back, 0% loss. Any ideas?
When I click download, the RSLinx window never pops up. I click download and it tells me to enter the graphic terminal IP address. When I do that, it says that the connection to the terminal failed.
From the Menu Bar in CCW, Select Device -> Setup Connection Path -> Browse to edit the path.
I don't use the Panelview Component HMI anymore but I recall in previous versions of CCW that downloading from CCW via ethernet didn't work well.
I usually exported the runtime file and loaded to the terminal with a USB stick.
I had the same problem. It never worked for me. I would edit in CCW than Download with web browser through the program built in the terminal.
I tried the USB method. I am getting an error that says there is insufficient disk space. There is currently nothing in the internal storage and the .cha file is 9 KB
I developed the program on Connected Components Workbench Version 3.00. It creates a .ccwsln file, but I need a .cha file to download. How do I...
7,854
Does anyone have access to a programmer's manual for this? Specifically, I am looking for instructions for the advanced toolbox objects such as...
1,042
I need to get an upload from a 2711C-T4T. I found an old thread http://www.plctalk.net/qanda/showthread.php?p=734222#post734222 on here that...
1,963
I am using a PanelView C1000 as the display and a MicroLogix 1400 as the controller. How do I use a floating point address (i.e F8:0) from the...
1,433
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,571
