Panelview firmware card in VMware issue
JZerb
Oct 2016
Here
423
Had to make a Panelview firmware upgrade usb stick this week in Windows 7 running in VMWare and every time right at the end of the firmware upgrade wizard it would pop an error when trying to create the autorun file on the usb stick. If I pointed the firmware wizard to a folder on the desktop it would create the file just fine then I would cooy and paste it onto the usb stick and all was well. Just curious if anyone else has run across this issue?
I've not had that one specifically, but as a general rule I always make sure I only ever work with files on the local hard drive with FTView. Network or external drives tend to throw unexpected and often misleading errors. I think my favourite was when trying to restore an application using Application Mangler...sorry, Application Manager, from a network drive. Well, actually, the "network drive" was actually just the shared folder between my host and my VM - it was still on the same physical drive - but the VM interpreted it as a network drive. The error message I got was "file is not a valid archive file".
It most certainly was a valid archive file - I moved it to the desktop and it restored fine. Ever since I've just made a habit of copying to and from the desktop when working with FTView files. Makes for less hair loss.
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
470
Hello! I have few Panelviews with corrupted firmware. I'm trying to reload it from memory card. So what I did: On known good unit I insert card...
2,595
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
209
Ive got an existing panelview plus 1000 with a logic module of 2711P-RP and an assembled pn of 2711P-T10C4D1 running out in the field. Its in an...
1,180
The panelview in question has been installed for over 2 years with no issues. Our facility has an extensive SE installation with a handful of ME...
1,255
