Panelview Firmware from 3.70 or 3.71 CD
MikeB
Sep 2005
Sydney
31
Hi. I made a mistake and tried to upgrade a Panelview 1400 to a version not supported by the hardware. Now I need to get back to firmware version 4.2 which according to Rockwell knowledgebase is on Panelbuilder 3.70 or 3.71 CD. I have CD's 3.80 and above, can't seem to locate an older one.
The actual file I need is
FW_Direct\2711-x14cx\C14TDHP.exe
can anyone help?
Ver 3.61. FW
From Ver 3.61
Couldn't find the 3.71 cd
Hope this helps
Change the extesnion to .exe, this is not an actual zip file, had to change the extension so I could upload on here
after the .exe version
thanks, although that file has a .fmw extension. Which is used when loading to a memory card. There should be another directory called FW_Direct or something similar that has the same filename with a .exe extension. Thats the one I'm after.
Try this one
I have attached the firmware executable as well as 3 more files on here.
I could send you the entir folder in a zip file though not sure I will be allowed to attach on here due to its size.
Send me a message with your e-mail if this doesn't work.
BK
it worked !
Thanks so much. Ran the DOS version you sent which actually used the .fmw file you sent previoulsy. All good...I owe you a case of beer !!
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
477
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
213
Ive got an existing panelview plus 1000 with a logic module of 2711P-RP and an assembled pn of 2711P-T10C4D1 running out in the field. Its in an...
1,186
The panelview in question has been installed for over 2 years with no issues. Our facility has an extensive SE installation with a handful of ME...
1,258
My panelview runs firmware 9 just fine. I would like to understand the justification to upgrade the firmware to the latest. I've been asked to do...
1,628
